- This topic has 13 replies, 2 voices, and was last updated 6 months ago by
♠️ M77.
Apr 11, 2026 at 10:05 AM #22258
ClayrParticipantBike Won’t Start™
I’m the second owner, only around 2300 miles currently. Was on the highway and the horn started blaring and bike began to rapidly lose power. Pulled over and turned it off. Had to bump start it to get home and it hasn’t cranked since without me sparking solenoid.
Bike dash turns on, horns turn signals are all good. Fuel pump primes when the kill switch is flipped but pressing the ignition does nothing.
Battery is brand new and was charged before being put into the bike. Spark plugs are brand new. (Iridium) All fuses, or at least all two that I’m aware of have been replaced as of the day prior to this post. (ATC 15A & 30A) Same thing goes for the solenoid. Recent oil change as of March (2026)
Could it be the positive cable? I’m convinced it can’t be negative ground cable since the starter wouldn’t turn otherwise. Any recommendations? It’s my first bike so I may not know all the jargon.
Apr 11, 2026 at 10:19 AM #22259
♠️ M77KeymasterHave you taken the tank off to inspect the harness for any signs of shorting or wiring burns ?
Was there any chance the old regulator likely popped one of the electrics ?
Horn is triggered by the left switch gear, disconnect it and see.
While it is apart, attempt to download the service manual on this forum , so it gives you instructions on getting an error code from the ecu (red icon will flash in a sequence which tells the error)
Check your neutral switch and clutch switch contacts/plugs = they would stop the bike from starting.
A bike violently loosing power with the horn blaring loud suggests either electric spike or a shorting somewhere but that is new to me also, all my years of dealing with hyosungs (mine and customer ones), this one is strange considering the bike is only 2k miles old. Practically young!
Starter is grounded to the frame and battery, so the long cable is the positive from the solenoid yes.
Apr 12, 2026 at 12:00 AM #22261
ClayrParticipantHave you taken the tank off to inspect the harness for any signs of shorting or wiring burns ? Was there any chance the old regulator likely popped one of the electrics ? Horn is triggered by the left switch gear, disconnect it and see. While it is apart, attempt to download the service manual on this forum , so it gives you instructions on getting an error code from the ecu (red icon will flash in a sequence which tells the error) Check your neutral switch and clutch switch contacts/plugs = they would stop the bike from starting. A bike violently loosing power with the horn blaring loud suggests either electric spike or a shorting somewhere but that is new to me also, all my years of dealing with hyosungs (mine and customer ones), this one is strange considering the bike is only 2k miles old. Practically young! ===== Starter is grounded to the frame and battery, so the long cable is the positive from the solenoid yes.
Might be worth mentioning that the bike sat indoors for about two or three years also the horn sounds off fine now. I’ve been looking at the wiring for the past few days and I haven’t seen anything my might indicate frying. I can try replacing the battery cables cause I really don’t want to have to replace the whole harness.
Apr 12, 2026 at 12:28 PM #22270
♠️ M77KeymasterYou can try replacing the battery cables and see what happens there on, a full harness replacement is usually last resort but they are getting rarer now as there seems to be a few left on ebay based on the ECU the bike has.
Apr 15, 2026 at 8:24 AM #22332
ClayrParticipantNabbed myself a multimeter and a few connectors incase anything was corroded. I was using the Ω setting to check the plugs for continuity (or something, I don’t the proper lingo.) The battery reads around 12.5 volts, I’m not sure if it’s supposed to read 12.8 volts since it’s not fully charged. I started with the red bullet connector on the lead wire and it’s working. Next I tested the solenoid which read the same voltage as the battery. I don’t think I tested the starter motor properly. I put one probe on the (+) of the solenoid and the other (-) on the starter motor. I’ll be honest, I have no idea what it was suppose to read. (I did get voltage from it) After that, I took off the right air intake fairing and found where the right assembly connects to the harness and checked each connection. Am I using this multimeter right? At this point, I have it set to the continuity beeper. Should I be touching the male and female connections with the probes at the same time or should I be checking a single cable at a time with both probes? Also when I was checking the connections on the voltage rectifier, there was a spark and it blew my 30A fuse. 🙁 I had a replacement one and the bike turned on fine. Finally, I jumped the solenoid and did a lap around 250ft. The bike was clunky and the fuel pump was priming the entire time. (Which is new D:) When I went to park it, I pulled the clutch in and the engine died, probably because of the fuel pump. I feel like I’m making it worse but I don’t know if I can get it to the local shop. Any ideas?
Apr 15, 2026 at 9:00 AM #22334
♠️ M77KeymasterIs there a chance of stripping the bike again and looking for any burn marks along the harness ? also where cables bend at the steering head + under the seat, look for fraying / chaffing ?
Check the sprocket cover and see if magneto cables have any fray or chaffing ?
If the Right Hand Switch Gear works (all buttons) , you wont need a meter on there, but make sure its black connector under the airbox is clean from any rust , debris etc that might disturb the signals , as the ECU does use the Kill Switch to communicate error codes to the dash when user flicks it 3 times fast before starting.
Since you can get a contact cleaner and air spray, spare a day where you can clean every single socket you can find on the bike and let it dry overnight.
⚠️ Don’t spray contact cleaner on the ECU! – Only dry air allowed.
You can clean the ECU plugs though, it will help with reducing some resistance from pin oxidization, so cleaner signals can pass through. Just make sure its been 24hrs before connecting all your sensors back, so it is fully dried out. it is still spring season, so air is still a bit damp to ride away immediately.
12.5V is OK but 12.8V is a charged battery
Running Idle = 13.5-14.5v max
5,000 revs = 14.5V maxAny higher , bin the regulator but becareful with TEMU style regulators , they will smoke the bike in minutes , just look at the last post here
Bike won’t fire cold but it fires once working = GT250R 2012
Apr 15, 2026 at 9:16 AM #22335
ClayrParticipantIs there a chance of stripping the bike again and looking for any burn marks along the harness ? also where cables bend at the steering head + under the seat, look for fraying / chaffing ? Check the sprocket cover and see if magneto cables have any fray or chaffing ? If the Right Hand Switch Gear works (all buttons) , you wont need a meter on there, but make sure its black connector under the airbox is clean from any rust , debris etc that might disturb the signals , as the ECU does use the Kill Switch to communicate error codes to the dash when user flicks it 3 times fast before starting. Since you can get a contact cleaner and air spray, spare a day where you can clean every single socket you can find on the bike and let it dry overnight. ⚠️ Don’t spray contact cleaner on the ECU! – Only dry air allowed. You can clean the ECU plugs though, it will help with reducing some resistance from pin oxidization, so cleaner signals can pass through. Just make sure its been 24hrs before connecting all your sensors back, so it is fully dried out. it is still spring season, so air is still a bit damp to ride away immediately. 12.5V is OK but 12.8V is a charged battery Running Idle = 13.5-14.5v max 5,000 revs = 14.5V max Any higher , bin the regulator but becareful with TEMU style regulators , they will smoke the bike in minutes , just look at the last post here
All the wires beneath the seat look fine. (As they’re wrapped in electrical tape for the most part.) Only thing of note is that the cable cover the comes out of the right assembly is bent very strongly. I’ll try the ECU thing in a few hours, will it be able to asses electrical issues? I really thought it’d be the lead wire messing with the ignition. I also checked for a tip over sensor and couldn’t find it for the life of me. + I tried unplugging the kickstand switch and starting, nothing. At least there are a few more things to rule out.
In the morning, I’ll attach photos of the ECU connector, solenoid to battery connections, and the connectors under the front left and right air intake fairings. Please let me know if there’s any other photos that might be helpful.
Apr 16, 2026 at 8:03 PM #22338
♠️ M77KeymasterThe tip Over Sensor is directly where the battery is , that yellow bar where your fuel tank sits on, unless it got bypassed.
Apr 17, 2026 at 9:40 AM #22346
ClayrParticipantThe tip Over Sensor is directly where the battery is , that yellow bar where your fuel tank sits on, unless it got bypassed.
I might be blind cause I haven’t seen it…
Could you tell me which code this is? I’m reading the manual and I’m not seeing a code for 10-5-10-5-10 or 1-7-1. This is how the F1 is flashing after flicking the switch 3 times
Apr 17, 2026 at 6:13 PM #22350
♠️ M77KeymasterFor a 2015 Delphi, you said 10-5-10-5-10 or 1-7-1.
I must assume 10-5-10-5-10 = ISC Error (Idle Speed Control Valve issues or errors or not detected etc)
1-7-1 is not found , the closest i can see is 10-1-1-7 = ET Sensor (Temp Sensor in the engine front cylinder) (Malfunction / Low Voltage) , it also says possible ECU malfunction or wiring harness.
The service manual will dive deeper in to the codes i mentioned as there should be a diagram on how to check with a meter too.
RO Sensor = The wires will be hidden in the harness if previous owner has cut it off ? = It is always by the battery area where the tank sits on, always, see where the 2 bolts of the tank screw in to? It is directly under there , very well tucked in and almost hard to access but it is there , it is also before the solenoid ball , then the battery box appears, right there in the center of the bike is where the RO sensor usually sits. Sometimes i get a hard time removing it myself to swap for another one.
Apr 23, 2026 at 4:43 AM #22378
ClayrParticipantFor a 2015 Delphi, you said 10-5-10-5-10 or 1-7-1. I must assume 10-5-10-5-10 = ISC Error (Idle Speed Control Valve issues or errors or not detected etc) 1-7-1 is not found , the closest i can see is 10-1-1-7 = ET Sensor (Temp Sensor in the engine front cylinder) (Malfunction / Low Voltage) , it also says possible ECU malfunction or wiring harness. The service manual will dive deeper in to the codes i mentioned as there should be a diagram on how to check with a meter too. RO Sensor = The wires will be hidden in the harness if previous owner has cut it off ? = It is always by the battery area where the tank sits on, always, see where the 2 bolts of the tank screw in to? It is directly under there , very well tucked in and almost hard to access but it is there , it is also before the solenoid ball , then the battery box appears, right there in the center of the bike is where the RO sensor usually sits. Sometimes i get a hard time removing it myself to swap for another one.
good news! Bike now starts. I took it into my local shop and the button was just broken. The bad news is that I’ve still got a check engine light and the fuel pump continues priming (loudly) while the bike is running. I believe it’s because of the Black cable with a white stripe that connects to the voltage regulator. It’s got a hole that I think shouldn’t be there. I’ll try and attach a picture.
- According to the manual, it does connect with the fuel pump so hopefully it’s priming constantly because it’s not getting enough power or something. So I plan to pull the cable from the plug, cut it, strip the end and reattach it. Is that a bad idea? Should I connect it a different way?
(Thank you for all your help so far btw, I would’ve long since given up if not for this forum.)
Apr 23, 2026 at 9:31 AM #22380
♠️ M77KeymasterThe fuel pump making a whirring sound is a good thing while running, it must keep running until you switch off the bike as the injectors need fast pressure fuel for injectors compared to slow fed carbs. A slight delay would cut out the bike.
The black wire , looks like a fire hazard, that’s the plug which gets power from the rectifier yes , don’t cut it, but make a very tight bandage around it using a very good electric safe black tape, so it doesnt touch anything else naked. Good excuse also to check all your other wires.
Regulator = I highly advise sending that regulator in the bin. It is the #1 most dangerous thing on the bike, as if it ever goes funny, it will smoke everything. No long term hyo owner keeps its , hence we always stress to use a trusted MOSFET Japan version , a real one.
Like this example here:
Upgrade Regulator Rectifier & Stator Magneto – Hyosung GV250 GT250 [EFi DELPHi 2011-2015]
BEFORE changing the regulator, please check your stator’s output , or show this link below to your mechanic:
Hopefully the stator is OK and all you need is just a regulator upgrade. probably the most imporant electric upgrades will be “Regulator (Mosfet) , avoid many million fakes out there” + NGK HT Leads (OEM ones are rubbish) + New OEM coils (Old ones be kept in garage for emergencies) , these three along should be enough for a long road trip this summer.
As for Error codes, unplug battery for 24hrs and reconnect, then see if new errors come up and tell us the sequences of the flashing red icon.
May 20, 2026 at 8:59 AM #22612
ClayrParticipantThe fuel pump making a whirring sound is a good thing while running, it must keep running until you switch off the bike as the injectors need fast pressure fuel for injectors compared to slow fed carbs. A slight delay would cut out the bike. The black wire , looks like a fire hazard, that’s the plug which gets power from the rectifier yes , don’t cut it, but make a very tight bandage around it using a very good electric safe black tape, so it doesnt touch anything else naked. Good excuse also to check all your other wires. Regulator = I highly advise sending that regulator in the bin. It is the #1 most dangerous thing on the bike, as if it ever goes funny, it will smoke everything. No long term hyo owner keeps its , hence we always stress to use a trusted MOSFET Japan version , a real one. Like this example here:
https://hyoriders.club/shop/service-maintenance/upgrade-regulator-rectifier-stator-magneto-hyosung-gv250-gt250-efi-delphi-2011-2015/embed/#?secret=fWcbISglTY#?secret=GYkB6W26Fu BEFORE changing the regulator, please check your stator’s output , or show this link below to your mechanic:
https://hyoriders.club/forums/topic/rectifier/embed/#?secret=jJeAUfjGpM#?secret=ulWa5CrWPV Hopefully the stator is OK and all you need is just a regulator upgrade. probably the most imporant electric upgrades will be “Regulator (Mosfet) , avoid many million fakes out there” + NGK HT Leads (OEM ones are rubbish) + New OEM coils (Old ones be kept in garage for emergencies) , these three along should be enough for a long road trip this summer. As for Error codes, unplug battery for 24hrs and reconnect, then see if new errors come up and tell us the sequences of the flashing red icon.
[quote quote=22380]The fuel pump making a whirring sound is a good thing while running, it must keep running until you switch off the bike as the injectors need fast pressure fuel for injectors compared to slow fed carbs. A slight delay would cut out the bike. The black wire , looks like a fire hazard, that’s the plug which gets power from the rectifier yes , don’t cut it, but make a very tight bandage around it using a very good electric safe black tape, so it doesnt touch anything else naked. Good excuse also to check all your other wires. Regulator = I highly advise sending that regulator in the bin. It is the #1 most dangerous thing on the bike, as if it ever goes funny, it will smoke everything. No long term hyo owner keeps its , hence we always stress to use a trusted MOSFET Japan version , a real one. Like this example here:
finally got around to buying the rectifier + stator. My only other question is are my connectors supposed to look like this? The connector coming from the rectifier has three pins and every one in the shop has 2 pins. Am I buying the right one?
May 21, 2026 at 5:45 PM #22617
♠️ M77KeymasterAll stators have 3 yellow wires to feed the regulator unit, just make sure the plugs match that’s all as Hyosung updated the plug shapes in later years.
