Forums 🚦 RIDERS LOUNGE 📸 Pictures & Projects Carbs removal GV250 2004/5 Reply To: Carbs removal GV250 2004/5
Nov 29, 2022 at 7:50 PM
#9172
Hi Marcel. You say I need to adjust the mixture screw to 2.5 turns out. I take it this is under a metal blank which I need to pry out? And therefore are the Air/Fuel rubber plugs in your shop to put in after adjustment?
Yes sir, here it is below:
click the pictures in the link to see where the mixture screw is located. PLEASE be gentle, it isn’t cheap and its very soft brass screw. If its tight or wont move, try air compressor or ultrasonic bath to get the dirt out.
Sometimes orings under it have probably cracked away (if you ever see fuel leak thru it or air hissing) (since it is “air/fuel” mixture)
