Forums 🚥 PiT STOP 🔧 Hyosung Technical Help 2010 EFI GT650R CHE on dash/no start Reply To: 2010 EFI GT650R CHE on dash/no start
Oct 14, 2022 at 8:53 AM
#8857
I’m really at a loss, I sprayed most of the connectors including the ECU and still the same result. I’m thinking I may have to remove the air box, and follow the wiring, and clean out every plug, and look for any kinks in the wiring, and if that doesn’t work….. I don’t know.
is there any way to test the ECU to rule that out???
