Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GT125 ’06 no power Reply To: GT125 ’06 no power
Aug 28, 2022 at 10:19 PM
#8465
By saying rev limiter I meant nearly end of red line.
I’m starting to feel the fuel pump is broken. When you pull the gas to nearly full then to zero-position and fast pull it again the rpms are getting higher for a moment at neutral. When you ride and do the same thing i feel the engine pulls for a short moment then again no power (I don’t know how to say it, again bad English)
Tomorrow I will check the back cylinder spark plug, airbox and I will try to skip the fuel pump
