Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Best products Reply To: Best products
May 20, 2022 at 11:07 PM
#7751
In my personal experience with ownership of multiple varieties (GV , GT and GTR)
I use these products all the time (plus the the bits sold at the shop section of this site, since i have to use what i preach)
- Motul 7100 , Motul 5100, Silkolene Pro 4, Silkolene Comp 4 = All in 10w60 grade or 10w50 grade. But 10w40 is fine all winter though.
Because the 125cc has a harder life, its a good idea to change oil every 1.5k miles with 2k miles being a limit.
4k on the manual is “too” optimistic because the clutch and gearbox start to get cranky/moody when oil has wanned after 2k miles. You want the transmission system silky smooth always and this means finding neutral while running won’t always be an issue. - Every bolt on the bike = Stainless or titanium, except suspension and axle bars.
It’s a must. - Use coppa slip on bolts that hold “plastics” .
- Use a “tear drop” of ACF50 on every single plug you encounter on the bike it’s a must.
- Google and buy on ebay “SUZUKI HARNESS” boot -> drop the oil cooler from its mount -> Hide the plugs from bad weather in to that suzuki boot.
- A 250 cooler helps 125ccs stay cooler. Especially faired bikes. and stops most mud trying to attack the carbs and rusting it up.
- “Any metal part” that moves (EXCEPT BRAKE DISCS) -> use Putoline GREASE on them.
- AutoGlym products are what i use to clean the bike and polish , wax etc.
It’s late but if i think of more times when my brain is a bit more engage , i’ll advise accordingly. Treat it well!
