Viewing 3 reply threads
    • #7715
      Peter Cavanagh
      Hi all
      As a new owner of a 21 plate Hyosung GT 125 I’m in need of some guidance/advice for best products to use…Oil, Brake Fluid, Cleaning/Polishing etc…
    • #7719
      Simon
      10w 40 semi synthetic oil now I use Smith & Allen limitless super 4t & have done for years in a multitude of bikes really good price really good oil in fact I have a ktm that I use their 15w 50 fully synthetic in never even had to adjust the valves. The important thing is to change the oil & filter regularly I do it twice a year march & October so before the winter & before the summer the oils cheap enough to make it worthwhile. Brake fluid dot 4, I recommend fs365 spray for winter use brilliant stuff.
    • #7722
      Simon
      I will add as oil threads normally cause all sorts of arguments this is my personal opinion. Having spent 40+ years working on everything from bicycles to 50 tonne excavators & having access to oil analysis equipment on the side the smith & Allen stuff has become my personal choice for pretty much everything except my highly tuned & crazy Honda dax which I have to run 20w 50 mineral Rock oil.
    • #7751
      In my personal experience with ownership of multiple varieties (GV , GT and GTR)
      I use these products all the time (plus the the bits sold at the shop section of this site, since i have to use what i preach)
      • Motul 7100 , Motul 5100, Silkolene Pro 4, Silkolene Comp 4 = All in 10w60 grade or 10w50 grade.  But 10w40 is fine all winter though.
        Because the 125cc has a harder life, its a good idea to change oil every 1.5k miles with 2k miles being a limit.
        4k on the manual is “too” optimistic because the clutch and gearbox start to get cranky/moody when oil has wanned after 2k miles. You want the transmission system silky smooth always and this means finding neutral while running won’t always be an issue.
      • Every bolt on the bike = Stainless or titanium, except suspension and axle bars.
        It’s a must.
      • Use coppa slip on bolts that hold “plastics” .
      • Use a “tear drop” of ACF50 on every single plug you encounter on the bike it’s a must.
      • Google and buy on ebay “SUZUKI HARNESS” boot -> drop the oil cooler from its mount -> Hide the plugs from bad weather in to that suzuki boot.
      • A 250 cooler helps 125ccs stay cooler. Especially faired bikes.  and stops most mud trying to attack the carbs and rusting it up.
      • “Any metal part” that moves (EXCEPT BRAKE DISCS) -> use Putoline GREASE on them.
      • AutoGlym products are what i use to clean the bike and polish , wax etc.
        It’s late but if i think of more times when my brain is a bit more engage , i’ll advise accordingly.  Treat it well!
