Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gt125 Comet will not start Reply To: Gt125 Comet will not start
Go with what simon says ,
Side stand switch = follow its wires and cut them. Ditch the switch. Join wires at the loom side. Please protect that area by waterproofing with good tape! I mean be ocd about this.
Clutch handle bar = follow its wires , the switch will say 0 ohm on the meter when you squeeze on and off on the lever, that means it’s dead. But luckily , i sell the clutch switches, should you need one!
Your fuel tap was posted today , so you should have it soon, we are in yorkshire too just as you are 🙂
When cranking the bike, the plugs will be sparking bright. This means its ready to fire. Dull yellow usually means bad coil, stator (it is also part of sparking due to its pickup sensor inside it), bad HT cap, or plug has broken down.
