Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Hyosung GT250R – Intermittent FI light Reply To: Hyosung GT250R – Intermittent FI light
My new fuel pump is not activating. The relay works as I tried a different one and got the same snapping noise. I checked the fuses. The F1 light will stay on
how do you find the neutral switch to see if it’s bad
How do you clear an F1 code to reset the ECU
it would be easier to start a new topic , then tell us the history of the bike and what problems its having , what you have been doing since then. It starts a new thread so we can follow up with ideas.
In the meantime, download either the 650 EFi or 250 EFi manuals on the forum, it will let you know how to check the condition of the ECU and what wire colours to check if there is a break / short somewhere in the harness.
