Forums 🚥 PiT STOP 🔧 Hyosung Technical Help relay socket that I can’t understand what it is Hyosung GV 250 EFI (2014) Reply To: relay socket that I can’t understand what it is Hyosung GV 250 EFI (2014)
Aug 13, 2025 at 8:49 PM
#20484
Hey, you can ignore it if the bikee is working normally. That is for dealer diagnostics or official hyosung scan tool (expensive and only given to dealers) , normally that 4 pin plug is hidden away in a rubber shield. So make sure that loose wire does not cause sparks or shorting!
Thanks for reply.
But I put a relay in this socket to see what it was for and then removed it. I hope I didn’t damage it.
Why would they make the diagnostic tool connection the same type as a relay socket? 🙂
Thanks again.
