Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Upgrading GT250R Suspension to GT650 Reply To: Upgrading GT250R Suspension to GT650
The forks i bought are black from a GT650, apparently 2007. My bike is 2008 GT250R.
Did they have black adjustable forks on a 2007 650?
I have the 650 manual for the 2010 bikes & the forks look the same but the max oil amount seems high.
The holes for the calipers to BOLT onto, on the new forks seem to line up with the old forks.
So 380ml Fork Oil should be ok & my 250’s brake calipers should bolt straight on. That was the plan.
My bike will not require the same damping as a 650 & the new oil is quite thick.
I just hope they fit as i’m excited about adjusting the compression & damping & having heavier springs.
My wheels are from a 650, so the original forks are not ideal due to the extra weight.
-----LaserBeam---->
