Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Issue with brake caliper pin – GV125 S EFi (Aquila 125) Reply To: Issue with brake caliper pin – GV125 S EFi (Aquila 125)
Feb 18, 2025 at 5:00 PM
#18940
You have 1 more chance === Try a BIGGER Allen Bit and hammer it in. Then turn it loose. Also spray WD40 to loosen any old road rust
or use bigger TORX bit and hammer it in, so that it is stuck hard on the bolt, then you have 1 chance to loosen it. Then throw it away.
I really recommend stainless pin FIRST before doing that , because you don’t want to re-use that damaged pin again (they used bad steel).
Stainless Steel Brake Caliper Pin (x1) (Pad Retaining Bolt Axle) :: Hyosung GV125-S EFi
