Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Abandoned gt650r problems Reply To: Abandoned gt650r problems
Oct 25, 2024 at 1:23 PM
#15343
#4 I have a suspicion about the fuel pump to be honest. The injectors respond as quick as the fuel pump sends fuel to them. See if the injector cleaner fixes it or improves the situation. I would get a new pump (not use) , just incase …. KEMSO is OK , it can fit in the housing of the pump, just make sure it comes with a strainer that faces down to suck fuel thats at base of the tank. Otherwise I hope i am wrong and it is just the clutch needing an overhaul (power from the engine has to go through the clutch to power the back wheels, so bad clutch may mean some BHP lossses)
Having new injectors is a not a bad call!
