Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Rebuilt front cylinder. Only 100 psi after rebuild – GT125R Engine Rebuild Reply To: Rebuilt front cylinder. Only 100 psi after rebuild – GT125R Engine Rebuild
Oct 21, 2024 at 5:29 AM
#15253
Amazingly the bike is running better than ever, psi is slowly going up on compression, had her running for ten minutes and its went up 10psi. I will need to lap the valves. Weather is aweful atm so will get them done when i can. Thank you for your help and support. Will i need a new head gasket again?
