Viewing 5 reply threads
    • #15243
      Brian
      As the title states, i have rebuilt the front head, got a piston, new rings, gaskets etc. Checked compression, its at 100 psi. Is this normal? Do they need time to seat? Thank you in advance
    • #15246
      Simon
      Did you lap in the valves?
    • #15247
      Brian
      No i didnt lap thr valves
    • #15249
      Simon
      When rebuilding the cylinder the valves need to be done it’s the most common place for blow by, normally worn rings/bores show with oil burning
    • #15253
      Brian
      Amazingly the bike is running better than ever, psi is slowly going up on compression, had her running for ten minutes and its went up 10psi. I will need to lap the valves. Weather is aweful atm so will get them done when i can. Thank you for your help and support. Will i need a new head gasket again?
    • #15254
      Simon
      Yeah always fit a new head gasket & remember the valve shims/ clearance will need adjustment.
