Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Where do these wires go? One attached to coil & one in the battery area GT125R Reply To: Where do these wires go? One attached to coil & one in the battery area GT125R
Sep 26, 2024 at 4:53 PM
#14951
Cut the yellow box off, that’s very suspicious!
The “Black & White stripe” of your wire from the harness goes to “Battery Terminal Negative”
Then it splits UP to also have an extra wire going down to the CLUTCH COVER (to give ground for your spark plugs and starter motor)
