Forums 🚥 PiT STOP 🔧 Hyosung Technical Help [How to Tutorial] Alternative Gas Fuel Level Sender/Sensor Gauges for Carby GT GTR Hyosung Reply To: [How to Tutorial] Alternative Gas Fuel Level Sender/Sensor Gauges for Carby GT GTR Hyosung
Some unknown sendors will be reversed saying EMTPY on the dash when the tank is actually full, i have experienced this myself. So Hyosung seems to be dead set on their dashboards making sure empty starts at at the base of the tank, as the float goes , the bars on the dash correspond to it.
either way based on my extensive tests of OEM hyosung senders, the ohms in this topic must match (or close to ) whichever sensor you would like to affix to the tank
Hope this helps
Toyota Hilux is common in asian countries where Hyosung is also present as alternative senders.
