Forums 🚦 RIDERS LOUNGE 😃 General Chat Dash not working, not starting gt650r Reply To: Dash not working, not starting gt650r
So this dash you are showing us now is the replacement one ? If so i would return it to the seller and tell them it isn’t working properly.
The “FI” light must come on next to the neutral sensor,
Hold clutch in (sensor trigger) and let go
Press Kill Switch On & Off on the big red button
Put it in gear so the neutral light goes out and hold clutch in ?
Put it in neutral so the N light comes back & double check the side-stand is actively bridged/bypassed
Can you let us know if pressing “start” , does anything to dimm the display or so much as hear clicks from the starting-solenoid ball thats next to the battery tray ?
Dont lose faith , it does sound frustrating what you are going through , like you i do also pray we don’t have to replace the harness and matching ECU but…..keep an eye out for local marketplace for a wrecked 650 that has a harness & matching ECU (Some ECU’s require specific harnesses)
