You will need to disconnect the neutral sensor to see if that takes the light away ?  = If yes, then issue is with the neutral sensor, it would be wise to replace with a correct one as Hyosung makes various neutral sensors.   Depending on the year of your bike.   The  “carb models” have 1 dot , and EFI models have 6 or 5 dots because the ECU reads what gear you are in until you circle back to neutral status.
Take the fuel pump out , and see if the strainer is OK = or post pictures here ?
Otherwise, the switching relay is needed  (it is better than a simple 30A fuse) ,  like what you see at this store.
Usually cuts or bogging issues tend to be based off the fuel pump,  if need be, it might need a new one.   It happens   (especially old pumps start to show their age and don’t perform as well as they did in their prime)
Disconnect the battery for 24hrs , and follow the service manual on this forum  (manuals section)  = > trick the ECU to give you a code and tell us what it is.
As this is ongoing,  keep us posted , we shall get to the root of it.
Fi   (not F-One)  , usually is pump , ecu , injectors.
In the meantime, go to halfords and only ,  i mean only  get this product exactly  (ignore the sales guy) and pour the whole thing inside your tank (whole bottle) , as this will be an aggressive mix to your E5 fuel.   This stuff should make its way to your injectors and start cleaning them out.  I highly trust it.
https://www.halfords.com/motoring/engine-oils-and-fluids/fuel-and-oil-additives/wynns-formula-gold-petrol-treatment-500ml-166754.html
