Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gt125R carburettor float height Reply To: Gt125R carburettor float height
May 8, 2024 at 6:53 PM
#13316
If the carb floats are facing the sky , the height is 7mm from the gasket surface. If the carb diapgram covers are facing the sky , they floats will move (come away from the carb bowls) to about 14-17mm ish. So be careful adjusting the float tangs both ways as not to overflow the carb (flooding) or giving too little fuel.
