Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Alternator / Stator Specs – GT250R 2010 EFi Reply To: Alternator / Stator Specs – GT250R 2010 EFi
Apr 19, 2024 at 1:05 PM
#13000
75VAC-90VAC max @ 5000 revs
If the object is ice cold overnight then
- Around 80-110 ohms pickup sensor
- 0.1 to 0.8 MAX (!) on each yellow line.
Yellow lines on the plug should test each other eg.
Pin 1 to Pin 2 = ohms
Pin 2 to Pin 3 = ohms
Pin 3 to Pin 1 = ohms
No need to ground to frame. You might infinity loops or errors on the meter.
