Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Cam chain tensioner Reply To: Cam chain tensioner
Apr 16, 2024 at 11:15 PM
#12975
The middle of the tensioner has a plug , remove it, and use a slot (-)screw driver , undo the tensioner unti it locks stop, this means the tensioner will retract, then you can safely put it back inside cylinder and screw again the middle (slot-) , then the tensioner pops out again to push the chain
If this makes sense ?
