Forums 🚥 PiT STOP 🔧 Hyosung Technical Help 2009 gt250 naked, kickstand wiring questions Reply To: 2009 gt250 naked, kickstand wiring questions
Jun 13, 2023 at 8:27 PM
#10530
The sidestand is definitely Wire One (BLACK & WHITE) and Wire 2 (SOLID BROWN usually or brown/black) – It goes to the CDI unit.
So i would join the two wires mentioned above ^ , then it is bypassed.
While the harness is exposed, you would take extra time to remove more of the tape and make sure there isn’t anymore fishy jobs except Korea’s factory crimping of joining common wires. Do not panic if you see 6x orange wires join at one spot then branch off as 2 wires again. That’s korea!
