I’ve got a question to ask the knowledgeable…
Can I swap my efi bodies for carbies? I’ve got access to a carbie bike that has its electrics intact but no engine.
Mucho gracias, Bondo
I already did that, but with a 250 EFI engine. I used 125 carbs, but I replaced the main and pilot jets. I had to replace the rotor and the stator in order to make the ignition system work. Now the bike runs, but I have some problems. I suspect it’s fuel starvation… I’m figuring it out.
To go from EFi to Carb 650 = All electronics from the donor bike will be needed front to back. And its airbox , its throttle cables , whatever was on the carby motor
Engine = Possible stator & flywheel change. Depends on age of donor bike and age of your motor
