Viewing 12 reply threads
    • #8250
      John
      👤 Member
      • Topics: 2
      Hi,
      I’ve just registered from Finland to ask opinions about a 2002 GV250 that I have a possibility to buy.
      I’m late 50s, 5’11 and 32 inside leg, looking for a first bike, ideally a cruiser of some sort.
      I’ve come across a GV250 for sale reasonably locally, 2002 model with 7000km on the clock as it’s been in storage for 20 years. Asking price is 950 euros.  It looks like new externally.
      What’s the general opinion, should I run away or snap it up, or something in between?
      With thanks in advance
      J
    • #8276
      👑 Admin
      • Topics: 40
      How well can you work on any motorcycle , ie what is your skill level ?
    • #8304
      John
      👤 Member
      🖊 Topic Author
      • Topics: 2
      Well, I’ve done plenty of work on cars and tractors over the years, but the only motorbike related fixing has been stripping and reassembling a couple of moped carburettors, adjusting valve clearances (again 50cc moped), and replacing brake pads on my son’s Honda cbr 125.
    • #8326
      👑 Admin
      • Topics: 40
      Then from what i have read, i say go for it and get it. If anything you will have fun restoring the Hyosung (though some days you may swear at it but efforts will pay off) , I could be biased to say get it so you can stay in this club haha.
      Honestly though the GV’s most common faults tend to be the paint work on the swingarm rust and such, so cosmetic restoration is where you will spend most time unless the bike is looking very good!
      Engine wise, if it sounds healthy like it’s purring like a kitten , you’re in good hands! – If it sounds like a helicopter, expect to rebuild the engine one way or another , but i hope it doesn’t come to that!
      Either way, as you learn about it, the forum is here for assistance , so get it if you dare 😉 ,
    • #8336
      Kernow
      👤 Member
      • Topics: 10
      Hi John
      The GV250 is the frame same etc size as the GV125.  I am 6’4″ with a 34 inside leg and size 14 feet, I find my GV a lovely fit.  I did play with the back brake pedal to make it a bit lower (put a longer adjuster bolt in).
      Go for it, a GV250 is easy to work on and a joy to ride for the taller rider.  At 950 Euros you will make money when you sell it on.
    • #8337
      John
      👤 Member
      🖊 Topic Author
      • Topics: 2
      Thank you both very much for your replies, unfortunately while I was away on my work gig the bike was sold, so now the plan is to seek out another. With hindsight I should have put a deposit on it, but we live and learn.
      Thanks again!
      J
    • #8338
      👑 Admin
      • Topics: 40
      Keep an eye out for ST7 and the GV650 versions of the bikes too, to be fair , you will even come across a 125cc version than a 250cc, least with a 125cc you will have an easier time working on it, when your bike does show up again, sell it or trade it in for the GV250 of your desire
      Same body = Different engines (125/250).
    • #8341
      John
      👤 Member
      🖊 Topic Author
      • Topics: 2
      Very good to know, thanks, especially that the 125 has the same size frame. A 125 could well also be adequate for my needs.
    • #8481
      John
      👤 Member
      🖊 Topic Author
      • Topics: 2
      Hi John The GV250 is the frame same etc size as the GV125. I am 6’4″ with a 34 inside leg and size 14 feet, I find my GV a lovely fit. I did play with the back brake pedal to make it a bit lower (put a longer adjuster bolt in). Go for it, a GV250 is easy to work on and a joy to ride for the taller rider. At 950 Euros you will make money when you sell it on.
      I wonder if the Aquila 125 has changed over the years, as I’ve just read a couple of reviews of newer (2020-ish) GV125’s being a bit cramped for longer legs?
    • #8484
      👑 Admin
      • Topics: 40
      The newer GV125-S as i’ve witnessed with my own eyes is definitely a little smaller than the older carby ones.  It’s because it’s more like  Half cruiser/Half Street naked bike   = think “Bobber” style.
      For fatness and comfort  (dare i say) , i would go for the carby GV125 (up to 2019) and it’s GV250 siblings (up to 2019 EFi model)
      However the newer GV125-S  and GV300S  (GV300SA) , i’ve seen people do modifications already to make the seat taller a bit , messed bars to make them higher etc,  not the end of the world!
    • #8505
      John
      👤 Member
      🖊 Topic Author
      • Topics: 2
      OK, well, I think I have another prospect to go and look at, it’s a GV125 though.
      The bike is a 2004 carburettor model, ridden 14k km, and it’s been parked in a barn for 11 years. asking price is around €600, owner has no idea if it starts or not.
      I wonder – I’m doing my A2 licence and had really been thinking about a 250 (hyosung, kymco venox or a virago) but perhaps as a 60 year old beginner the 125 would indeed be a reasonable option as previous replies to this thread would suggest. I weigh about 95 kilos but might be able to get this down 😅.
      I was wondering of course if people here had any thoughts? I realise that I’ll need to replace the fluids, tyres, battery…
      -J
      Edited to add what kind of mpg could I expect from the 125, would it be less than the 250?
    • #8514
      👑 Admin
      • Topics: 40
      MPG wise i would say the 125 will have a slighly better MPG than a carby 250 does due fact less piston size , and lesser jetting but still lives high rpm life>
      ie. 10k revs in 3rd gear for 40mph in 125cc, the 250 would achieve that in less reves, just an example  (not accurate, just a guess)
      Fortunately it’s easier to change gearng of the 125 in to cruise mode to use less revs and a bit less fuel  , by upgrading to a 520 chain and sprocket set.   The slim 428 chains aren’t worth wasting too much money on a heavy bike that will stretch and vtwins by nature start their power at lower revs than a big cc inline 4 bike.
      Go get the 125 🙂 , and ofcourse ignore whatever the previous owner did to , always assume its 0 miles (no matter how old it is) and be ready to give if a fresh overhaul of servicing from the get go , usual like tyres brakes filters , fuel lines, suspension checks and all that stuff.   if you dare , stripe it down to bare frame while leaving engine inside and just clean up the parts with a nice drag and wipe down the frame from any mud, road traffic film and or oil spills from oil changes or chain grease gunked up inside sprocket cover with a good de-greaser
    • #8515
      👑 Admin
      • Topics: 40
      If its a barn find,  it will mean straight away an ultrasonic clean of the carb and do check the tank doesnt have rust inside , and as safety measure , replace the fuel tap too.
