Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Jetting a GT125R – 2017 ..? Reply To: Jetting a GT125R – 2017 ..?
The cams on the rear face up but torwards each other.
But look at the edge of the cam shaft bars and make sure the dark black _________ line is on the same level as the surface of the cylinder head (where rubber gaskets sit)
Both cams must be equal ________ marked to match the surface of the engine gasket area.
Also if i remember correctly (it’s 10pm, so my brain is a little funny!) , the #2 on the sprocket is 100% facing straight up | ^ to match the cam cover holder bolt thread.
#3 on the sprocket for the intake is facing UP but it will be like this / than | straight up
Spin the crank 10x to be accurate and recheck feeler gauge for clearances.
