Forums 🚦 RIDERS LOUNGE 📸 Pictures & Projects Back-up race bike build Reply To: Back-up race bike build
Little bit of progress.
I’ve carried out a couple other checks with the electrics and I think my coils are my problem. I tested the resistance on my magneto pick up coil and charging coil and they are both within spec (0.6 ohm and 109 ohm). I was also getting a small voltage through the coil primary wire when pressing the starter for a couple seconds, so I’m hoping that means my coil theory is right. I have ordered a pair of coils from a wrecker, so hopefully show up next week.
Also put my forks on and discovered why the bike came with 3x fork legs…… 1 is bent! If I can be bothered, I’ll have to get around to painting the leg bottoms both black.
While I’m waiting for the coils, next on the list is to look at the rear brake system.
