Forums 🚥 PiT STOP 🔧 Hyosung Technical Help gv 125 wont go in gear Reply To: gv 125 wont go in gear
Apr 28, 2021 at 9:36 PM
#5789
You may want to drain the oil.
Put back the plug with the spring in the right order , spin the wheel until you can select first gear (center stand) or rise the rear. Leave engine off.
Pray no damage was done when engine was running cause the gearbox does have a cam shaft of its own.
Hope this can quickly fix it and let us know. Id hate to pull it apart too.
