Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Bike start’s but revs to 6k after upgrades. Reply To: Bike start’s but revs to 6k after upgrades.
Go to the stator.
Follow the wires going up to the main harness.
Ignore the regulator. Dont disconnect it. Not even its 5 pin solo plug. Leave it.
The stator has its own 3 PIN yellow plug.
Disconect AT the bike harness (you will find it as you find out where the stator finally joins the harness.
Just 3 yellow pin plug. unhook just that.
Now start the bike and rev to 5k revs and hold it there.
Set your meter to AC volts.
See the yellow 3 pin plug of the STATOR ? do this.
Pin 1 and Pin 2 = Put your meter red and black probes in any order.
Get voltage readings at 5k revs.
Next…..
Pin 2 and Pin 3 = what is the voltage?
Pin 3 and Pin 1 = what is the voltage?
Now…
We have measured across all 3 pins and reply back with 3 separate values.
Pin1+2=40v / Pin2+3=34.5v / Pin3+1=25.8v as example.
Set your meter to AC 200 volts or AC500v (beyond 200AC)
