Forums 🚥 PIT STOP 🔧 Hyosung Technical Help Downpipes Reply To: Downpipes
Jul 14, 2020 at 12:32 AM
#4686
If you stick with the standard air filter and end can then no. The stock downpipes are sleeved to half the diameter of the outer pipes and the standard can is too, which would maintain back pressure. But if you’re using a different end can, or have changed the intake system in any way you’ll need to up both jets to next size. You might find you need to fit a baffle too if you’re using an aftermarket can as loss of back pressure means you’ll get zero power at full open throttle.
