Jul 15, 2019 at 9:04 PM
#3005
Hey Tomas,
Just read through the post, but to start the bike and get it running we have to go through the following:
- Battery is 12.8V charged? And isn’t “old” (ie. a local garage can test the battery for free so you know the cells inside are good , not just a volt check) Starter motor draws a lot of juice to crank those 2 pistons, so battery has to be a 14BS type (12-14ah as per books) but i’ve seen folk use 9ah. They don’t last well.
- When you press the starter button = Do the lights dimm?
If yes, then its either the solenoid / starter motor or just a weak battery (though it says 12v!)
If no, then check the harness for these:
– Clutch handle bar switch (not really advised to bypass it but they do lol)
– Sidestand switch (bypassing is highly recommended) it is that annoying.
– Neutral Sensor should be 1pin and the harness 1 pin or 2pin sensor for 2 pin harness. Mix matching is a hit n miss some bike looms don’t react well.
– Kill Switch unit , if moisture got to the bike in winter, check inside the switch for clean contacts and ACF50 (a tiny tear drop) on every electrical plug on the bike will kill off rust and keep contacts fresh. - Starter Motor = Remove it’s LONG black wire, put your RED METER wire on it.
BLACK METER wire should be on the frame or battery negative.
Press START
See if there is power going there ?
If yes, the solenoid must be activated by the start button => so starter motor should spin?
If no, the solenoid may not be working. (Very common) - SOLENOID = If you hear clicks (even faint) when pressing the start button. That outright should tell you that device needs attention or the battery is too weak to crank the bike.
- CDI Unit = As with carb 125s , the CDI will check the parts above ^ before sending any sparks to the ignition coils.
GT250 M815 or GT125 M795 are the only CDI’s that work on carb 125 bikes (all of em). So the 250 cdi you have should be fine if it is stamped with the correct numbers i just mentioned ^ . After all, you said earlier in to the project the bike ran fine with it. A GV/Aquila cdi just wont work anyway lol.The bike will CRANK on the button WITHOUT a CDI and REGULATOR/RECTIFIER. It just won’t obviously spark but this last resort of elimination can help check if the harness is good.
- STATOR = Part of the ignition system. Bike wont crank if the STATOR trigger sensor isn’t working. Grab your meter , switch to OHMS (200 ohms max) then ..
Grab the “BLUE & GREEN” stator plug = Probe the plug
See how many ohms comes out of it? I’ll confirm its good or not.While at it, check how many ohms you also get on the stator 3 YELLOW PLUG (yellow wires) ====> probe those pins , and see how many ohms you get across all 3 pins
The 2 images below are cartoon versions of what i’m getting at , this should help you when checking the harness. You can save the images to blow it up full screen on a phone while working on the bike.
