Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Bike won’t fire cold but it fires once working = GT250R 2012 Reply To: Bike won’t fire cold but it fires once working = GT250R 2012
Hey you mentioned, sometimes it has starting issues when on kickstand, is it bypassed ? and if yes , remove the bypass to check if the wires had internal corrosion, it happens sometimes with these new Gen RC machines.
Also check your tilt-sensor or replace it ? if your mechanic can use a tilt sensor from another bike, it is also called RO Sensor (Roll Over), bike maybe thinks you fell down ? so it shuts off sparks & starting, it can happen, I am not sure it is a good idea to bypass it (heaven forbid the bike falls in the garden and it is still running!)
