Forums 🚦 RIDERS LOUNGE 😃 General Chat Hyosung GV650 2013 Model struggles after exactly 20 minutes of riding every day Reply To: Hyosung GV650 2013 Model struggles after exactly 20 minutes of riding every day
Check this out
Your will see it by your cylinder heads towards the radiator unless it got relocated by previous owners.
Also browse this forum again in the Technical section, and where it says MANUALS, get the 650 version for a service manual, it will go in to detail about troubleshooting temperature issues of the bike or to diagnose the cooling system , it can also show you readings you should get from your meter when testing cooling sensors such as THERMO FAN SWITCH, Radiator Sensor (aka Temp Sensor) , Engine Temp Sensor – And see if you can report back your findings.
They don’t want to touch the bikes? That’s silly, but little do they know Hyosung was partly responsible for Suzuki’s early days as they made parts for them and helped make the SV650 distant cousin!
You will do a better job than them, you got this!
If you struggle, just add photos in your next comments!
