Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Dies on idle (after 1-3 minutes) – GV250 Reply To: Dies on idle (after 1-3 minutes) – GV250
Thanks for the links Marcel, I actually just fixed the bike a couple hours ago. The sparks were completely fouled and the tips on both were white, this is from when the fuel pump was dying, and eventually it fully went and the bike was stuttering before the pump died. Also I put like 8000 miles on them too, one thing I seem to still have though is a hunting idle, the ISC and TPS and fuel pump are new so are the coils and the sparks. Only thing left I can think of is the caps themselves or maybe something to do with charging? Though I will say the bike does charge and stay at a constant 13.4v idle and it gets up to 14v under load. Maybe some new caps and rectifier will make it run better than factory though and the hunting will subside 🙄 Thanks for your help Marcel!
