Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GD250R Fuel Tank Removal Reply To: GD250R Fuel Tank Removal
What other parts need attention on the GD250 ? We could elaborate what ever the manual isn’t making sense of.
Manual is OK for most parts as GD/GDR share the same parts under the plastics.
GD250N / GD250R = Plastics and extra fairings and race-look.
Tank is the same and so is the pump, however they are expensive to replace and easy to break the pump connector, so lift very very slowly and unclip the high pressure hose carefully and then tank can be put away to the side , keep in mind there is likely the ECU attached to the tank or regulator. Hyosung has moved parts around the GD250 & GD250R frame under the tank to try cool down either the ECU or Regulator.
I had a different bike in the past that had its ECU mounted under the tank (on the tank itself) and i almost yanked it off! – I learned to be slow in everything now.
