Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Dies on idle (after 1-3 minutes) – GV250 Reply To: Dies on idle (after 1-3 minutes) – GV250
Ok will do, ill test the ET (IAT im assuming you are referring to on the GV250), I need to check if its getting 5v cause I tested all the sensors but couldn’t read 5v from the IAT sensor. Ill have to test while cranking as well cause that might be the culprit, but honestly my fuel lines while dont have any kinks or cracks they still are old and a little spotty, some spots have like rubber particles around them. For the majority it doesn’t look bad but could be that, but i’m also heavily leaning towards injectors right now too. Ill have to figure out a way to test fuel pressure, because I know there is no Schrader valve, Hyosung’s while nice bikes they sure suck when you have to work on them 😕 especially the early efi models… thanks for the replies marcel hopefully its something simple but honestly my harness has seen better days so really at my wits end with it. Wish me luck, lord knows I need it.
