Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GT250R 2007 – Bike not starting (\'N\' light not lit up) Reply To: GT250R 2007 – Bike not starting (\'N\' light not lit up)
but a side stand switch wouldn’t prevent the n light to not work
most likely your switch on the neutral as failed https://www.google.com/search?q=neutral+switch+gt250r&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjN7Orq87LfAhXdRxUIHbRbDr0Q_AUIDigB&biw=1920&bih=939#imgrc=dJRoA4WclxsPEM:&spf=1545463408601
if you follow the clutch wire switch it will lead to where its connected usually they go where gearbox is and undo it and clean and put back but theres a chance cleaning it this time may not work but its worth a try you will after remove left side panel
also check your cdi make sure theres no burnt hole or damage as that can cause it not to start
