Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Missing 5th gear? – GV125S Bobber 2022 Reply To: Missing 5th gear? – GV125S Bobber 2022
Oct 2, 2025 at 9:17 PM
#20940
Take a look under the tank (becareful as the fuel pump “port” is very fragile when disconnecting it) , then take the tank off. Look for connectors coming from the sprocket area and clean them then contact cleaner (wait to dry) then try again ?
Glad to hear the actual gearbox is still working!
