Forums 🚥 PiT STOP 🔧 Hyosung Technical Help No spark gt125r 06 Reply To: No spark gt125r 06
Used a wrench slowly to try lift it up once again the left side would lift but the right side i was able to make it wobble a bit (tiny bit) the gasket seems to wobble when I give it a little pry with flat head, but I can’t seem to get the right side off (the side that had the 2 nuts) could the 2 long screws be culprit the ones i took the nuts off? They are very rusty, did spray wd40 on it a day ago. I tried a bit of hammering, some soft prying with wrench, was even able to lift the engine up by just holding the head, thats how strong its on there. Yet that side wont come loose. No idea what to do gasket seems free and am able to move piston (obv after I push the head back in place as slightly lifted from left). Rn its at the top
