Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Slow throttle response on low throttle – GT250Ri Reply To: Slow throttle response on low throttle – GT250Ri
Sep 11, 2025 at 3:58 PM
#20741
Funily enough, my bike doesn’t have any tps even though it’s and EFI, one less thing to check, I guess. I did find a loose airbox tube to the intake, which I have tightened correctly, and I took the time to change sparkplugs too. The issue seems to have improved, but I don’t know if it’s a placebo or not. Did have the chance to spray brake cleaner to check for leaks since I didn’t have any, but will probably do that, and if I find anythin,g I will check it and if not I will just assume this is the normal harshness o the bike
