Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Ignition barrel replacement – 2010 hyosung gt650r Reply To: Ignition barrel replacement – 2010 hyosung gt650r
probably means Fi light was flashing ? You may be getting a sequence flash ie,
Fi light blinks in a sequence = 5 blinks , pause , 6 blinks , pause , 7 blinks (it repeats itself)
567 code = could mean EFi system thinks battery is too low to power everything on it especially the pump too. (code 567 is just an example)
If its not that, go to the 650 manuals section of this forum and download the service manual that matches your bike (Daewoo Korea ECU or Mitsubishi Japan i am guessing based on 2010) , the manual will show you how to read the flashing sequence.
The dash could say “Fi / 0 / Fi / 0 ” but also test your stator using this guide below and tell us the ohms
(ignore that it says 125cc, the principal is the same)
get ohm readings for the coils that spark your plugs and HT caps too , tell us
if you have extra time, drain oil nicely ==> Remove the stator cover slowly as not to rip the gasket that may get stuck to the engine crank, and see if the stator is burnt out.
if in doubt, upload some pictures here.
