Do I start chucking money at it!?
Probably,
The bike still isn’t happy = Look at your own spark plugs , will tell you exactly if its electrical / fueling / or poor air system. (Rich vs Lean vs Poor Electric Sparking)
Bike will not ride perfect unless all 3 work in tandem (air / fuel / sparking electrics)
I would read my replies above ^ on this topic = write down as a list. tick off every single checkpoint.
Fueling Parts & Carb OK & checked over? = then we are done with the carbs.
Then the electrics or plugs would be your enemy , I would go here below …
(GV125/Gt125 = same engine, same carb, same coils = same behavior)
(Follow my replies in those threads, as i go quite deep on electric dramas & HOW to test them yourself)
1. https://hyoriders.club/forums/topic/gt125r-no-power-between-4k-8k-revs/
2. Another Topic Here
3. And this one too!
Yes,
Faulty Coils & Regulators happen to all hyosungs. They are just a cheaply made parts that die out eventually. The japanese win when it comes to electrics.
— > Could also explain your plugs not doing their job or otherwise fouled/annoyed
Remember this always:
High revs / RPM needle stuck high / very slow to drop revs down = Air Leaks (anything air flows thru) or CV sliders stuck or choke is not off (still on choke)
Boggy / Jumpy Revs / Laggy = Electrics (inspect all including plugs , can’t stress spark plugs enough) or Fueling Drama (anything that petrol flows through)
