Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Exhaust Downpipe Rust Reply To: Exhaust Downpipe Rust
Hi I was looking at exhausts. However contacted backwidow and they direct me to the fuel injection type exhaust however mine is an 09 carb model. I am struggling to find a new exhaust for mine and mine is dead it’s been welded however badly corroded and needs new system. Have a new silencer on it max torque can.
Hey!,
I wouldn’t panic – “All years” of Carb & EFI vTwins of GT250R & 125R use the same pipes. Same fitting too.
BlackWidows makes the pipes for Carb & EFI , yes correct , but they will send you a “blanking” bolt. Call them and ask them to make sure a blanking bolt is included.
Refer to the image below:
Having said, this would also be the case with Scorpion or MTC UK exhaust companies – They must send a blanking bolt for carb models , if they send you EFI pipes
If you need a stock/standard pipe system that is in a good nick , please call “Startrights Leeds” & tell them this:
Looking for a standard exhaust system for GT125R , in used condition – Marcel says you have the orange hyosung for stripping (I sent you)
They will discount it for you & post it direct. 👍
Their website -> http://startright.co.uk
Good luck, welcome to the forum!
