Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Rear shock very soft suspension Reply To: Rear shock very soft suspension
May 22, 2025 at 6:30 PM
#19604
Yes you need fairings off, then use jacks to rise the bike up safely. Then remove the shock from under the bike , adjust it while it is out of the bike
OR if you have very small strong hands, go where the rear brake reservoir is, use a C-Shock tool to rotate the shock a few more clicks until the springs feel stiffer.
