Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GV650 up and back risers? Reply To: GV650 up and back risers?
Apr 29, 2025 at 5:36 PM
#19448
Yes the further back you pull the bars, the longer the cables you may need unless you are able to carefully find a way to reroute everything ?
or if the backrest can have its cushion pad removed , then find some aftermarket pad thats much much thicker and get it stitched up in some leather hide , this should push you further forward of the bike?
Post a picture of your ride to see what setup you have currently too , that would be cool to see.
