Forums 🚥 PiT STOP 🔧 Hyosung Technical Help No spark gt125r 06 Reply To: No spark gt125r 06
Mar 10, 2025 at 7:26 PM
#19082
Hi, i did check both primary and secondary resistance of the coils.
The cap readings are (multimeter set to 20k)
Coil 1: 8.73ohm
Coil 2: 10.40ohm
Regarding that blue wire that goes from cdi unit to pickup coil. I’m not sure if it is faulty as i was not getting continuity when i hooked the multimeter to the pickup coil end of wire and to the cdi end of wire.
Oh and will purchase that regulator once I order the other parts, so do i go ahead and order the stator and pickup or should I do more testing?.
