Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Brake Caliper Choices Hysoung GT250R 2008 Reply To: Brake Caliper Choices Hysoung GT250R 2008
TCTC Silver = Identical (Every Hyosung before EFi era)
So yes, you can get rear GT250 calipers , remove the bracket , and put them on your front mounts no problem.
Just bleed nipples may face down or up! (TCTC is funny like that!)
GV250 Front Caliper = Same as GT250R front , just swap the mounts as GV uses different forks that’s all. The actual caliper is the same.
KR Motors doesn’t sell calipers on their own, they “have” to come with mounts , probably why he said “i only have rears” . As Hyosung Korea pre-fits the mounts at the factory as they make them after TCTC sends the calipers to them.
We can’t buy new mounts separately that’s why , they come with the calipers as a whole set.
No problem, least you have a spare rear mount!
