Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gt250 almost no compression Reply To: Gt250 almost no compression
Nov 16, 2024 at 3:18 AM
#15535
Ordered : floats ,pins and needle valves this evening. I won’t have the parts for a couple of weeks. I am unclear where to measure the 7mm for the float height and what position the carbs are in. I the manual section I do have,it seems the measurements are with the carbs upside-down,17mm from the carb bowl seam/flange to the now top of the plastic float.
I really appreciate all the help
