Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Inconsistent rpm at idle, stalling + jerky acceleration GT250 EFI 2010 Reply To: Inconsistent rpm at idle, stalling + jerky acceleration GT250 EFI 2010
Nov 12, 2024 at 9:37 AM
#15508
Engine Compression is very good! TPS = It looks OK , the manual says replace it if it causes problems because we can’t manually make adjustments to it.
Glad to hear that the compression is very good 🙂
Next step will be to order a new ISCV, and before attaching it check all of the wiring from the ISCV to ECU I guess.
I will keep you updated. Thank you!
