Forums 🚦 RIDERS LOUNGE 😃 General Chat Hyosung gt650r critical design flaw? Reply To: Hyosung gt650r critical design flaw?
Aug 11, 2024 at 1:09 AM
#14451
LaserBeam, thanks for the compliment mate. Your suggestion is exactly what I ended up doing in the end. I had the shock and linkages removed for cleaning and servicing. There’s quite a few bearings in those linkages that needed a clean and fresh grease. All looking pretty much good as new! I ended up just shaving a flat spot on the bottom coil where it had been rubbing on the swing arm. Just the bare minimum to give it clearance then applied some rustguard paint to seal up the bare metal. All is good now! I’d post up some pics if I could of course!
