Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Float height adjustment – gt250 Reply To: Float height adjustment – gt250
Jul 24, 2024 at 3:09 AM
#14225
UPDATE:
Set floats to 7mm and put the carbs on the bike. It idles now and I am able rev the engine however only with a very slow input of throttle. If I give it a moderate turn it’ll cut out. Furthermore, If I rev it and it comes down to idle it’ll cut out (e.g. 5000rpm -> idle).
I have not made any adjustments to the needle groove settings.
I have an auxiliary tank plumbed into the carb fuel intake that is gravity fed only just in case that has anything to do with it.
